Weird Spikes in Waveform Graph
Hi student,
@hmcengstudent wrote:
Thank you for the video suggestion!
Did you actually watch that video yet?
In your VI you can delete ALL constants (except VISA reference) wired to ConfigureSerialPort as you use the default values! The TermChar should be enabled as others already mentioned…
Watch the video and read the scale manual (as explained in the video)!
Your string handling is also very convoluted: if you would set a typical "read string" as default we could offer improvements for conversion of the string to the "mass value".
Message 11 of 11
(154 Views)
