Weird display problem...
I have a weird problem using NI OCR Training. I don't know why, but the font size is way too big and because of that, I can't see some of the parameters (see the picture in attachment). I don't think I've change the font size in the past. I've checked with a friend Windows settings (Advanced Appareance) and we have the same thing. We checked in the options of LabVIEW and we have the same thing in the settings of the font. Even if the window is maximized, the problem is still there.
Anybody knows why it's doing this?
Thank you very much
Stephanie
(2,978 Views)
I think it's a font problem. The software, client-software was written uses standart windows font, but your standard windows font is a little bigger than the string indicator.
So look in your windows settings fror the standard font or probably change your DPI-setting in windows settings. May be you can select the font shoulb be used in the software from popup menu.
(2,949 Views)
Thank you Eugen,
It was the DPI 😉
Stephanie
(2,932 Views)
