Weird waveform chart X-Scale behaviour
I am having trouble with my waveform chart...  I'm not sure why the x-scale is not ... 'attached' (for lack of a better word) to the plot area.  Why is it larger?  It's throwing my graph off, since if I leave it on autoscale, it won't let you scroll to see the whole plot, since parts of it are hidden by the non-plot area.
Currently all scales have been defined by me, and I have adjusted the size of the plot area, but I have done the same thing with other graphs and not had this happen (but I have run into other weird scaling issues with LabVIEW).
Anyone had this happen to them or know why it's happening?  Thanks.
(3,769 Views)
I can solve this problem two ways, but neither of which I think are the 'correct' solution...  if there even is one.  One, I can just edit the control, and resize the x-scale manually (however this is imprecise, since I can only guess the exact number of pixels), and two, I can delete the graph and create a new one, but this is annoying since there are a lot of attributes attached to it.  Is this a bug in LabVIEW?
(3,757 Views)
I had similar problems with LV's digital graph. What I ended up doing was using the graph's property node to set the X-scale dynamically based on the data I got and clock rate used. So the X-scale will have the correct mulitplier factor for displaying samples or timebase.
(3,752 Views)
I have also used that in the past, but can't for this particular application, since the clock (loop iteration) time is variable....
(3,745 Views)
Could you post your code, it looks like you are setting the x-axis incorrectly.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,734 Views)
This is a problem that occurs on rare occasions for no apparent reason:
Just do the following:  Right-click on the graph ---> "advanced ... reset scale layout"
(See also for example: http://forums.ni.com/ni/board/message?board.id=170&message.id=106639  )
Message Edited by altenbach on 07-06-2005 10:19 PM
(3,734 Views)
Thanks for the suggestion Altenbach, but when I do that it puts all the Y-Scales on one side, and when I try to "swap sides" on those scales, it simply reverses the text, and doesn't move the scale to the other side.  I guess I'll stick with what I've done, which is just have the control manually edited.
As for setting the X-Scale...  I'm using the WDT as the source data for the chart, and thus the X-Scale (I was hoping) would work itself out.  I had previously had it autoscaling, and it was working exactly as I had hoped, but then I was playing with some of the tools on the graph palette, and what's shown in the picture happened.  Which forced me to manually set the scale.
I suppose I can't complain too much!  The ease of graphing is one of the things I like best about LabVIEW
(3,721 Views)
