What MS SQL Server Express version should I install?
How you connecting to SQL? use UDL file if not used. Read page 3-5 and read how to configure UDL file. Make sure you following same procedure
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 12
(684 Views)
I suggest you to go step by step.
1. Make sure UDL is configured as I told.
2. share your VI(in 2011) so that we can check any issue with the VI only.
--Ranjeet
Message 12 of 12
(676 Views)
