What Xlinx FPGA's are able to use labview?
This is my first time posting on the forum so I do hope it is in the correct place.
My question to the forum is pretty simple and straightforward.  How can I tell if a certain FPGA is compatible with LabVIEW?  For example if I wanted to work with LabVIEW on the spartan-3A DSP series, or the spartan 7 series.  How would I be able to discern whether or not it is capable of using LabVIEW.  Furthermore, after determining compatibility what steps would I have to take to get that compatibility functioning, or is it as simple as just installing LabVIEW?
Thanks in advance on any help.
(2,386 Views)
Hi Student,
LabVIEW FPGA supports all FPGAs in NI hardware...
The point is: use NI hardware.
(2,370 Views)
I only want to use a similar FPGA as NI.  I do not want to have to purchase a RIO.  Would Labview still be possible?
(2,365 Views)
LabVIEW FPGA module is only usable with NI hardware. What do you want to achieve actually?
(2,355 Views)
