What am I missing about clusters?
I went back to one of my older VI's to try to clean it up using clusters. I thought I understood how to do it, but now it appears that I was wrong.
"3002D-R" is the old version; it works fine. "3002D-R cleanup test" is the attempted cleanup, and it doesn't work. The most obvious problem is that hitting the lock switch or STANDBY knob will turn the white-on-black voltage display back to 0000; I haven't played with it much beyond that, but I'm guessing I'd have a good chance of seeing other differences.
I don't understand what's wrong here, even after highlighting execution, but I'm guessing it's a property of clusters that I'm not understanding from the help files.
Ideas?
(The third VI is a sub-VI used in the first two.)
(3,208 Views)
Why are you bundling the "current V"? Remove that lowe bundle element.
Message Edited by altenbach on 11-19-2007 05:48 PM
(3,194 Views)
The problem has nothing to do with clusters. In the old version you only changed current V when the knob changed, in the cleanup one you change it after every iteration. In other words with the new one you set Current V to 0 when you go to stand by, which you didn't do with the old one.
[edit]Looks like altenbach beat me to the punch, and with pictures[/edit]
Message Edited by Matt W on 11-19-2007 07:51 PM
(3,192 Views)
*facepalm*
Thank you! I'm at a loss to explain why that wasn't glaringly obvious to me...
>_>;
(3,183 Views)
