What are the PCI 6024E ANALOG OUTPUT PORTS on terminal block CB-68LP
Dear All
I want to get analog output signal on physical output. In my LabVIEW block diagram I develop the DAQ-assistant and I configure ao0 as analog output. The voltage I want to masure is analog -5v to+5volt. On terminal block what will be the physical analog output port on which i measure this voltage.
Waiting for ypur response.
Kind Regards
Irfan
(2,942 Views)
I think you are confused.  You use an analog input port if you want to measure a voltage.  You use an analog output port to generate a voltage.
As to what terminals to use, check the manual that came with your PCI card.
(2,939 Views)
Dear Sir
I am attaching Block diagram. In DAQ-ASSISTANT1, I was able to read the real time voltages that I give on port 68,34 of terminal block. I do some signal conditioning and do FFT analysis of acquired signal. Now after performing FFT I want to take magnitude of FFT signal at physical output of hardware. Then I will give that signal to microcontroller input. So for that purpose I am using DAQ-assitant 2 and configure it as analog output.
Regards
Irfan
(2,927 Views)
The PCI-6024E has both analog inputs and outputs, so you should be able to do this.  And your VI seems okay.  I would consider wiring the stop button to the analog output DAQ assistant as well.
So what is your question?
(2,920 Views)
My question is If I am giving 5v to DAQ-assistant 2 then at which physical port of terminal block voltage will be writed. Mean physically on which port of terminal block I will get output signal.
(2,915 Views)
Accepted by topic author tronoh
In MAX, you can simply right click on the device and select 'Device Pinouts'. The DAQ Assistant will also show pinouts.
(2,881 Views)
Dear Sir
I am very much thankful to you for providing guidelines to me.
Kind Regards
Irfan
(2,869 Views)
