What are the following vi highlighted in red (see attachment)...............
Can someone tell me what the below highlighted vi's are. I have installed the DAQ drivers, but the below two vi's are missing from the Functions Palette. Should I download a different set of drivers? if not, under which section can I find them.
Please help.
My END goal is to build a basic system with PID and DAQmx.
I am using LabVIEW 2019.
Thank you,
(2,113 Views)
The selected VIs are:
  • The first one seems to be Get Full Terminal Name.vi: This VI is shipped with some DAQmx examples (LabVIEW Help Tab > Find Examples.. > Hardware Input and Output > DAQmx), and I found one located in: C:\Program Files (x86)\National Instruments\LabVIEW 2019\examples\DAQmx\Synchronization\SubVIs
  • The second one looks like a Merge Errors implementation.
I recommend you use Context Help (Ctrl + H) to get more information about VIs when you're in doubt of what a function does or how it's called. You can also right click over them and select Explore... to see where they are on disk.
All the best,
(2,063 Views)
