What are the steps necessary to get EPICS server to publish when deploying on RT cRIO
I have been using LV for many years and just began using a cRIO 9074 RT.  I am able to build and run/deploy simple VIs on the cRIO, but cannot get the EPICS server to publish the PVs to the network.  I have spent many hours researching examples and white papers, but can not find a good example of deploying an EPICS server on the cRIO.  ( I have successfully used EPICS on computer based systems)
Does any one have a step by step example relating to EPICS deployment on a cRIO (Real Time)?
(3,256 Views)
Accepted by topic author TecRix
Turns out the PVs were being published.  Just have to know how to look for them.
(3,236 Views)
Care to elaborate on this?  I want to give it a try but had issues earlier using LV based EPICS server.  Its' defaut port number didn''t match whate we use here and the value could not be changed.
Had success in regular LV using CA LAB but not sure how to install on a RT system.
Thanks for any insight before I waste a lot of time.
Jim
(3,076 Views)
