What can I do for a reoccuring Line 33 error?
I keep getting a Line 33 error when I try to close one of my pop-up sub-menus. I've programmed a "Settings" window to pop up and close when I choose the "Continue" option on its menu. And it pops up ok, but then everytime I try to close it, it calls up a line 33 error and closes all of LabVIEW. I'm attaching the Failure_log.txt from this program. What can I do?
(2,407 Views)
dsoakley,
There is a published KnowledgeBase for this error in using LabVIEW 6.1. You can get to it here.
You may also want to post what file had the error instead of having to look inside the failure log and give a better description of what you VI does and what it calls. I would also include what version of LabVIEW you are using. It is best to give more information than what you think is needed so that this forum can be the most helpful.
Randy Hoskin
http://www.ni.com/ask
(2,407 Views)
