What causes Window XP Clean up desktop message to lockup LabVIEW application?
While running aLabVIEW application, A Window XP Clean up desktop messagelockup a LabVIEW application.  The window message interrupted theapplication and lockup the application.  LabVIEW has to be restarted.This application had most user inputs inhibited, and the task bar was disabled.
(2,915 Views)
I've never seen that happen. What is your application doing? What is the normal CPU loading from it? Have you gottne it to happen more than once?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,907 Views)
I don't remember seeing that either, but the cleanup wizard is invoked rarely enough so that I hardly see it anyway.
The easiest solution is to disable the wizard in every new computer, since it doesn't really make sense in our systems. In XP, this is done by going into the display settings dialog and clicking the customize button in the desktop tab page.
___________________
Try to take over the world!
(2,890 Views)
