What could be the possible reason for a deployed application to run slow after the target pc comes out of standby mode?
What could be the possible reason for a deployed application to run slow after the target pc comes out of standby mode?  PC running XP and using the USB to communicate with the DAQ and driver boards.  Application generated with 2010.
(3,511 Views)
Is this a PC or a laptop? If it's a laptop: Is there a power supply or is it running with battery?
Furthermore: How do you define "slow"? What happens in your application?
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,490 Views)
On some PCs, USB 2.0 operation might be slow after coming out of Standby mode.  Do a search on 'USB standby slow'. Might need a driver update or perhaps change how your system sleeps.
(3,477 Views)
Usually default property is checked
  system property -> devices ->usb root -> power management -> allow system to switch off device
Hope this help
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,458 Views)
Using a Dell laptop D910 with battery plugged into ac outlet.  Loop timing can be off between 300 - 500 ms.
(3,443 Views)
With the setting in default mode does that mean its never stops running?
(3,442 Views)
It probably is something along the lines of a resource taking time to start up. Try setting it manually to leave the USB device powered on instead of whatever the default is.
- Regards,
Beutlich
(3,382 Views)
