What diagnostics are available to troubleshoot relays on digital sidecar?
When using the simple Relay Sample code - none of the LEDs on the digital side car will light regardless of choices.  We have tried 2 cRIOs - 3 side cars - 2 cables - in all combinations - all yielding the same results.  The PWMs work properly on the digital side car.  The Digital I/O work properly on the side car.  We have power to the side car.  Not sure what other items to check/diagnose.
(2,705 Views)
What is a "digital side car"?
(2,695 Views)
EHM, that sounds like a FIRST question, you should post that on the FIRST forums.
(2,680 Views)
