What do the error codes "100" and "536870914" mean when I tried to communicate with my contollers.
I encountered these 2 errors when I tried to read my Newport MM4006 motion stage. I suspect that could be a address problem between the two controllers that I use. Any suggestions?
(3,977 Views)
Hello-
Usually LabVIEW's "explain error" can identify all errors. Not so in this case. It must be an instrument driver specific error. It may help to use highlight execution to trace through the VI to find the source of the error.
There was a driver for the 4000 on ni.com/idnet, but it was contributed. If further assistance is necessary, it may help to contact the developer of the driver. It is likely the instrument manufacturer, Newport.
Randy Solomonson
Application Engineer
(3,977 Views)
