What do you need to install to run a deployed executable with IEEE?
I'm having trouble to communicate with my IEEE device thru LabVIEW.  I just want to double check if I installed the right things.  I developed my application in LabVIEW 8.0, and deployed an executable to a test system.  The test system has the IOTech IEEE Driver, and the LabVIEW 8.0 Run Time Engine.  I just want to know if I need to install anything else other than the run time engine.  Please dont' go into the compatibility of the IOTech driver and LabVIEW.'
See-Ming =(
(2,566 Views)
If you're using it, VISA and IVI drivers would also have to be installed. Since you are using an IO Tech device, then they would be the best ones to ask about problems with their board. Doesn't it come with some sort of utility that you can use to communicate with an instrument? With an NI board, you get MAX.
(2,554 Views)
yeah.. it does come with a program to communicate with the card
the problem is, I'm having problems communicating thru LabVIEW, but not the utility program.  And this only happens on my test system, not my development system.
Oh well.. I'll keep calling IOTech and see if they can help..
Thanks!
See-Ming
(2,539 Views)
