What does a "?" mark mean in a shared variable
I have a numerical indicator where I right click on it to create a local variable.  The local is created, but instead of having the name of the indicator shown, it displays a "?".  What does this mean?
Message 1 of 9
(3,819 Views)
It means that your control or indicator does not have a label. Give it an intuitive name and all will be better. 🙂
If you think it already has a label, check to see if it is actually the caption and not a label
If you don't want the label visible on the front panel, hide it (right-click...visible items...), don't just clear the label string. 😉
Message Edited by altenbach on 02-19-2008 04:22 PM
Message 2 of 9
(3,817 Views)
Eureka!!!!  Oh wait. Huh.....
I turn on the label and it says "UpperRise 1", I turn on the caption and it says "UpperRise 1"
I now have an indicator on my front panel that is displaying both the caption and label and they are the same.  Smiley Mad
If I create a reference, it displays the correct indicator name. If I create a property or invoke node, the label (yes is it visible) is blank.
If I ask the node to link to ---->   It shows it as currently connected to ".2"   Cool.
Thanks for the idea (I thought this was a duh moment), but this appears to be much deeper than that.
Message 3 of 9
(3,810 Views)
I find using the Control or Indicator properties is a good way to sort out the names and captions, and which (if any) are displayed. All in one place. Saves much right-clicking!
Message 4 of 9
(3,798 Views)
Can you attach a small sample VI containing your objects mentioned?
Message 5 of 9
(3,793 Views)
Attached.
BTW, these are "colored" locals, not the black & white locals when you delete an indicator and leave the unattached variable.
Message 6 of 9
(3,769 Views)
Very strange...those indicators somehow became corrupted.  I recommend submitting these to ni.com/support so the AEs can send a CAR to R&D for investigation.  For now, you can fix the problem by creating new U32 indicators and deleting those old ones.
-D
Message 7 of 9
(3,760 Views)
You can also rename the control and the local variables will update accordingly.  --How did you get the local variables into this state?
Message 8 of 9
(3,751 Views)
Yes, very bizzare....
I went through last night and recreated about 8 controls that had gotten corrupted like this.  It's all happy now.
How did I do it?  Good question. Same way I managed to corrupt my .proj file or the various times I have had to delete and recreate build specifications. I am an engineer, it's my job to break things!!!! I've got about 3 CARs right now that R&D is digging into. Smiley Very Happy
Message 9 of 9
(3,746 Views)
