What does error code -10452 mean in simple english and how do i solve it?
When i try to output a volate on any channel i get the error code -10452 at AO control, no interrupt level is available for use. What does this mean, and how can i solve it?
(2,909 Views)
This error message means that there is a resource conflict with your data acquisition card and another device in your computer, specifically an interrupt level.
I would recommend using the DAQ installation wizard at http://www.ni.com/support/daq/ to make sure your card is installed correctly and not in conflict with other devices. Once you have selected your OS and DAQ card, you can view the Resource Conflicts article that is under the common problems topic. This article walks you through a series of steps to realize and resolve your resource conflict.
(2,909 Views)
