What does it mean when control of a class is blurred?
(3,558 Views)
What do you mean?  Can you post a picture?
(3,530 Views)
This control has unapplied changes.save your type def and
Menu file. Apply changes
Honestly, I think that that? Should be one click if the "Automatically update from type def is checked.  NI does not agree.
(3,523 Views)
This option appears disabled. To solve the problem, I had to drag the controls of the class back to the front panel, and in that way, load correctly. Is there any other way to do this?
(3,465 Views)
This happens with a type def control has been modified but not committed. There are two things that cause this.
  1. You have the typedef open in another window, in which case go File> Apply changes.
  2. A change has occurred to a cluster control that cannot be automatically changed on your VI. For example when there is a named object in your cluster that has been removed, LabVIEW doesn't know what to do until you right click on the control and make manual decisions about the arguments.
These problems also break your VI, so you can use the Error window to figure out  what your problem is much faster!
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(3,454 Views)
