08-04-2008 03:04 PM
I am testing my
Then I build the VI code in a project and generate a successful executable. When I run it it seems fine until I end the
… has encountered a problem and needs to close. We are sorry for the inconvenience.
In that box, I click on one button to pop up another message box. There is “Error Signature” section. It says:
AppName: my_gui.exe AppVer:1.0.0.6
ModName: xerces_c_2_2_0.dll ModeVer: 2.2.0.0
Offset: 00126db7
I am not sure what it actually tells me about the code.
Thank you so much for you help in advance!
LV 8.2
08-04-2008 03:29 PM
That message tells me very little as well.
Do you recognize the name "xerces_c_2_2_0.dll ".
My gut tells me there is an issue with that dll.
Ben
08-04-2008 03:39 PM
08-04-2008 03:42 PM
After this reply I suspect my help to you will diminish greatly.
Are you closing everything that gets opened correctly before shutting down?
Please post back with your solution when you find it. I'll be off-list for a couple of days.
Ben
08-04-2008 03:49 PM
08-04-2008 04:03 PM
08-04-2008 04:07 PM
Close sessions, connections etc
Ben
08-04-2008 04:49 PM
08-04-2008 05:38 PM
