What does this CRASH reflects??
HI,
I've been coming across the following crash incident very oftenly(many times in a day). Can some one pls point any understandable meaning in it for me?? The following is just one of the top lines from the very fresh crash report which is also here enclosed as a simple text file.
c:\builds\penguin\labview\branches\Jupiter\dev\source\typedesc\TypeManagerObjects.cpp(321) : DWarn: You should not be calling TMBeginTransaction in the middle of an UndoRedo prop types!
$Id: //labview/branches/Jupiter/dev/source/typedesc/TypeManagerObjects.cpp#36 $
Smiley Happy
(4,580 Views)
What are the circumstances around the occurance of these crashes?
What OS?
What version of LV?
What are you doing?
What is LV doing?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,565 Views)
Mike, thanks for showing interest.
What OS?
windows NT
What version of LV?
8.5
What are you doing? , What is LV doing?
Performing DAQ operation and storing them in access database. Here I very oftenly get error  about "opencommand object" which I am also thinking to be the culprit. please refer to my following old post regarding to it.
This error(opencommand objest) occurs randomly.
Message Edited by Parny on 11-09-2007 12:49 AM
(4,559 Views)
How are you connecting to Access? What are you trying to do?
Mike...
LabVIEW Champion
(4,556 Views)
Just a side note:
According to the release notes, LabVIEW 8.5 does not support Windows NT.
(4,537 Views)
My apologies,
The OS is "Microsoft Windows XP Professional Service Pack 2 (5.01.2600)""
Also enclosing here, with MAX configuaration report.
(4,506 Views)
Got some feedback from the NI support, sharing the info here.
Thank you for your queries. I've looked at your log file and noticed that
this is a DWarn message. DWarns are not fatal so LV will generally keep
running - does LabVIEW crash when running the VI? Or do you get this error
dialog on startup?
If LabVIEW doesn't crash and the VI behaves as expected we can disable the
specific DWarn so that you won't get this messages again. Please let me
know if you would like to know how to do this. Otherwise we can start
troubleshooting the cause of the error.
For starters, the error log file indicates that the error occurred while in
'dau_stand3_U.vi'. Can you reproduce the error with this VI? Is the error
intermittently appears?
DWarn is a warning that occurred during the last time you were using
LabVIEW. By default LabVIEW does not show a dialog at the time of the
warning since it is not critical to execution. However, it is hard to
identify the cause of the DWarn without knowing when it occurred. By adding
the following line to your LabVIEW.ini file you will see a dialog
immediately when the error occurs, which will help you (and NI) identify
the cause.
DWarnDialog = TRUE
It will show a dialog and halt execution of your program when the DWarn
error occurs. Please let me know how you go with these tests.
Kind regards,
Linda Kurniawan
Applications Engineering
www.ni.com/support
(4,220 Views)
