What driver package should i install to use serial ports
Hi !
I just want to use a serial port. But the Labview installation doesnt install serial port drivers. What is the smallest package that will install serial port drivers ?
Martin Desjardins
(2,569 Views)
you can just install the VISA runtime engine.
Michael.
(2,558 Views)
You need NI-VISA.
If you are using a serial port interface card/unit then you also need NI-Serial.
(2,556 Views)
