What equipment do I use...
Hello NI Community,
I need your advice and expertise.
I would like to control the flow of water (mass flow of 0.01 Kg/s)  using LabVIEW ideally via usb.
My problem is I don't seem to be able to find any mass flow valves for liquids that have a computer connection and then be compatiable with LabVIEW.
Can you recommend some manufacturers, websites or even products that fit my specification? Does NI have something that I could use?
I know I haven't provided much to go with, but if someone could point me in the right direction it would be very much appreciated.
(2,129 Views)
Accepted by topic author Rahms
You will probably not find a mass flow valve with a computer interface, but there are lots of mass flow valves with analog voltage controls (0-5V or 4-20 mA). Then if you purchase a USB module from NI with the appropriate analog output to match the valve you will be in business.
Richard
(2,122 Views)
