What happened for ActiveX position?
Please check the 2 pictures,shows the difference when VI run.
I use my own menu and close system toolbar when run in VI prorieties.
*The best Chinese farmer*
(2,951 Views)
There is no toolbar while the vi is running, which can be setting in VI property of File menu.
(2,894 Views)
I mean that the height of ActiveX control has changed. Woudl you adverted that?
First picture 2 controls at same height, the second one ActiveX control has been moved.
(2,848 Views)
Any solution?
(2,815 Views)
