What happened to the Get/Set Date and Time utilities from RT 7.1?
I'd like to use the Get/Set Date and Time utilities that were available in 7.1, but disappeared after that. I see that the 7.1 utilites  call a dll that does not appear to be installed with LabVIEW RT 8 and later. What do I need to do to use the utilites from 7.1 that do not appear in later versions?
"All truths are easy to understand once they are discovered; the point is to discover them." -- Galileo Galilei
(3,372 Views)
In Labview 8.2 and later there are two directories for vi.lib. settime.dll is located in National instruments\Labview 8.2\Targets\NI\RT\ vi.lib
This is the dll you want to use in order to call it use the same Vi as in 7.1 (RT set date and time.vi) and link it to the correct dll.
(3,334 Views)
