What happens if CompactDAQ gets disconnected?
Hello Smiley Happy:
For a costumer I need to work with a NI cDAQ-9178.
What does this device do with it's in- and outputa if the usb connection is disconnect.
Do the digital/analog in- and outputs of the modules keep there last state or do they reset to default.
If the latter, what can I do to reset the in- and outputs to a safe state, given that the cDAQ has no logic like a CompactRIO?
Thank you in advance and kudus will be given! Smiley Happy
(2,864 Views)
On my quick test on an analog output device it held its last value when USB was removed but AC power remained.  I never knew that.
(2,826 Views)
Thank you sir
(2,798 Views)
