What is Best Practice for how to move VI from Parent to Child Classes?
I have a project with one Parent class and two Child classes.  I have a need to move a VI from the Parent class to a child class and move the VI from the other child class to the Parent class.
The Project example looks like this:
Is there a way using the Project to easily move the VIs with a minimum number of steps?  I can move them and reselect the lvclass control.  I can accomplish this with more steps than what I would like.  (moving in the project, pointing to the new class, applying library icon, moving on disk, making SVN know what happened, etc.)
What I am asking is the easiest way to do this.  What is the best and easiest method?
(3,369 Views)
I generally use the "clone method" feature of LVOOP Assistant for this kind of thing (though that still leaves the extra step of deleting the original method, so it's not a easy as it could be).
(3,354 Views)
Or you could use G# . It has a Move Method function that renames, moves on disk, applies icon, all in one go. It supports LabVIEW-native classes too.
Certified LabVIEW Architect
(3,277 Views)
How about leaving the VI in the parent and making it dynamic dispatch?  Create an override in the child class?
CLA
(3,250 Views)
