09-25-2007 04:27 PM
09-25-2007 04:42 PM
10-05-2007 11:53 AM
10-05-2007 11:31 PM
10-07-2007 10:46 PM
Ravens Fan,
I know, date wise, when it was created as I installed all of the NI software DVD's in one sitting. The Academic Site License (ASL) includes (when MultiSim is included as I have it) over 40 programs if they are all installed. I have the HDD space, so I installed everything. At the end of each DVD's install, the request to reboot is prompted. But because of the way the ASL is packaged, that last DVD alone installs about a dozen programs and extensions to others. Hence the confusion as to which program the uninstall goes with. If I'm not mistaken (and if so, I apologize) but I think the standard (non-ASL) installs come on discrete DVDs and install only one program or suite at a time, which would make it easy to figure out where the problem lies.
My curiosity was aimed at reuniting the uninstall with the correct program, just in case I ever need to remove a single program and in case someone else out there ever needs to. The problem may be limited to the ASL, and if so, is probably not a big enough deal to worry much over.
Thank again for the help.
