What is CLUSTER ERROR IN AND ERROR OUT?
See the picture:
I don't understand what is error in and error out?
I have read the text, but I ask: when ths error in start? All Icon have a error IN, but where is the first possibility of error?
If I have understood very weel I MUST CONNECT ERROR OUT OF EACH BLOCK WITH ERROR OUT OF NEXT so i can have a controll of error in  my process?
It's ok?
Vanny
)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(
Sweet, Beautiful and Young Female Physicist (SBYFP)
(I speak a not very good english, so If U are Italian LabVIEW expert speak in Italian, if U speak in Eglish... please speak easy;) )
My e-mail for personal contact: vanessaricciardi@live.it_NO_SPAM_PLEASE
(7,484 Views)
You should connect error out of any block to error in of following block.
In order to manage errors, you should verify if an error has happened on application-critical points, then decide how to proceed according to your needs...
(7,483 Views)
Nevertheless, you should start with basics of error handling
(7,469 Views)
The error-in/error-out wires serve two main purposes:
1) It helps control data flow. In text based languages, flow (in general) is top to bottom.
 In LabVIEW, it is directed by wires, so you can pass consective functions with their error clusters.
2) The error clusters allow the programmer to do error handling however they would like,
as well as establish what error specifically is causing the problem.
Cory K
(7,453 Views)
