What kind of property node is it? The problem is that it's not correct, so you should check it. If it's a VI server property node, be sure the reference is properly opened, and that you don't close it. If it's an activeX property node, be sure your activeX library is registered in your system, and the automation opening vi is properly adjusted.
Hope this helps
