05-22-2007 07:38 AM
05-22-2007
10:07 AM
- last edited on
08-13-2026
09:01 AM
by
Content Cleaner
Hi Tpmjones!
This seems to be an issue where the nce file gets corrupted and because of that it can't be imported by MAX. My first question would be, what version of MAX are you using? if it's below 4.2, i strongly recommend to download the current version, since MAX comes with the DAQ driver the way to get it, is downloading the current version of daqmx. After upgrading MAX (if needed) hopefully the issue of the corrupting nce file will be solved.
The next link is to the daqmx version 8.5:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MLhSAM&l=en-US
I hope this information helps you, don't hesitate to post the result of all this.
Best regards!
Oswald Branford
