What is Run Time engine 5.1.1?
I came across on our network a Runtime engine 5.1.1 program for LabView??, Can anyone tell me what this does or can do?
(3,030 Views)
The LabVIEW Run-time engine (RTE) is needed for compiled LabVIEW exes to run.  So if you have any applications (exes) written in LabVIEW 5.1.1 then the RTE would need to be installed on the machine that uses those exes.
It basically consists of the shared primative functions in LabVIEW as well as the code needed to actually run the LabVIEW exes.  The LabVIEW RTE is similiar in behavior as other languages RTEs.
Message Edited by Evan on 02-24-2006 10:18 AM
(3,025 Views)
Hi Dennis
This is a free utility you can download from the internet. It is simmilar to Matlab runtime engine, which you need to install if you want to run executables written in LabVIEW.
This is an old version (few years), the new is 8.
Take care
Pawel
(3,018 Views)
Thanks everyone, this helped alot.
(3,013 Views)
