What is best way to output wave graphic which come from Digital Oscilloscope into word docs?
I want to capture wave graphic from digital oscilloscope  and save into word.
From digital oscilloscope, i can get data array for wave. But i don't know how
to output wave into a word file. Should i save this graphic to a file firstly,then load it
into word by program?
please give me a better method about this? I don't handle this before.
Thanks.
br
Message 1 of 12
(3,996 Views)
Am sure you can able to take a screenshot (Print screen) with the help of drivers for that oscilloscope. You can get .jpg files. Is there any specific requirement to save it as word docs? Post your oscilloscope model number and tell me whether you are using LabVIEW drivers for it and can you able to take a printscreen of the waveform from the oscilloscope.
Mathan
Message 2 of 12
(3,994 Views)
You can get the image data of any control or indicator, and also the front panel. Depending on your Labview version you may also make reports in HTML format and save it. The functions needed is included Base version
You can also purchase a toolset for making word format reports.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 3 of 12
(3,982 Views)
hi Mathan
I mean i can get wave data by visa interface and these data can be used to create a graphic in labview.
I want to insert the graphic into a word docs. But i don't do it before and want to find help about it.
THanks.
Message 4 of 12
(3,970 Views)
mmm2006 wrote:
hi Mathan
THanks.
I didn't quite understand. You mean you want to collect waveform data points from the oscilloscope and create your own waveform graph in LabVIEW with the help of the collected data points? Correct me if i am wrong.
Mathan
Message 5 of 12
(3,966 Views)
I think the easiest way is to get the image data from the front panel or indicator. Then save it to a picture file, and insert it into word. Do you need help with this?
Message 6 of 12
(3,964 Views)
You didn't answered my question yet. What is the model no of the oscilloscope you are using? Are you using any drivers for the instrument? If so i hope there are functions like these.
1) Instrument I/O --> Waveform--> Configure functions--> Get Waveform.vi
       With the help of this you can collect the wave data from the instrument.
You can get the points in the array and you can send it to a waveform graph very easily in LabVIEW.
Post if you want something else.
Mathan
Message 7 of 12
(3,964 Views)
I think you are not worried about the waveform but you want to output the frontpanel graph into a word document. Basically report generation right?
Message 8 of 12
(3,944 Views)
A quick and dirty method I often use then I write documentation is to stop the Labview program. Then I copy the control/indicator and just paste it into Words. It will be pasted as a bitmap picture
Message 9 of 12
(3,940 Views)
hi, Coq Rouge
Thanks. I think it is a good method.
Message 10 of 12
(3,913 Views)
