Hi Walter,
You'll get the best performance with both writing and reading by using 512 byte chunks. LabVIEW RT 7.0 and later use file caching to optimize performance, so working with 512 byte chunks isn't as important as in previous versions, but you probably will see an improvement.
David H.
Systems Engineer
