What is consider a "large" tcp/ip string
Is 114,000 bytes considered a large tcp/ip string and should I break up one single write into multiple smaller writes? Or does it not really matter? I don't know much about what tcp is doing on the low level in the background.
(2,589 Views)
Don't worry about breaking it up; let your operating system's TCP stack handle that for you.  It knows how large a packet should be and can combine multiple small writes into one larger one for the same destination, or split a large amount of data into appropriately-sized packets.
(2,569 Views)
Thank you Nathand!
"An answer from you is better than a guess from me." Smiley Wink
The added beauty is error recovery if the network paths have to be reconfigured durring the transfer. TCP/IP guarentees they will be delivered intact or an error will be returned.
Ben
(2,567 Views)
