What is difference between Power Spectrum and Power Spectrum Density?
My unserstanding is that
S(n) : Power Spectrum
nS(n)/RMS^2: Power Spectrum Density
Thanks in advance.
Juntack Lim
(3,036 Views)
There is a great resource in the LabVIEW Analysis Concepts manual.  Specifically from chapter 4 page 27:
Because of noise-level scaling with Δf, spectra for noise measurement often
are displayed in a normalized format called power or amplitude spectral
density. The power or amplitude spectral density normalizes the power or
amplitude spectrum to the spectrum measured by a 1 Hz-wide square filter,
a convention for noise-level measurements. The level at each frequency line
is equivalent to the level obtained using a 1 Hz filter centered at that
frequency line.
I recommend checking out that manual.  Please let us know if you have any other questions!
Travis M
LabVIEW R&D
(3,019 Views)
