What is error 1620
I'm encountering an error during installation.
(2,962 Views)
Randy,
Which LabVIEW version are you installing?
What is the OS?
Which part of the installation returns the error?
What does the log file created say about the error?
All of this information is needed to troubleshoot the error.
However, the error is probably caused by the driver installation from the LabVIEW CD. I would recommend you do a custom installation and first install only LabVIEW. Then install any drivers you need from the CD. If the driver installation still gives you problems, you can download the latest driver versions from our web site:
Drivers and Updates
http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US
Zvezdana S.
(2,962 Views)
