What is he order of installion for the labview 7.1 cd's
I aqm trying to install labview 7.1, everytime I try to install one thing, it tells me I need to install something else to intall all the features of that item. There must be some sequence you are supposed to follow, do you install the one labeled Labview & express first, or measurement studio first, or do you instal the drivers first, or what, Please help
(2,394 Views)
You first have to install the CD labeled LabVIEW. When you have choosen there to install device drivers you are prompted to insert the Device drivers CD 1. Dependend which components you have choose you are prompted to insert the device drivers CD 2.
If you plan to install modules and/or the Measurement Studio together with LV I would first install LV and deselect the device drivers, next all LV modules and at last Measurement Studio. This should give to the following CD sequence: LV, LV modules, Measurement Studio, Device Driver CD1 and Device Driver CD2. After that install any toolkits.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,389 Views)
