What is "Measure Slot" ?
Can somesone explain what is "Measure Slot" doing for?
(1,219 Views)
Hi 23219a,
I guess when you read the manual of your Tektronix TBS2000 device you will find an explanation for this parameter…
(1,207 Views)
From the driver comments :
"Obtains a waveform measurement of the specified measurement slot and returns the measurement value."
So it is choosing from which slot you are getting the data. I suppose that "Immediate" would use the present channel that is already selected in the isntrument.
If you have the programming manual check at this : *WAI;:MEASU:%s:VAL?  where %s is replaced by the choosen channel.
(1,188 Views)
