What is "gated region" and "gate length" mean?
I am programming a program about ultrsonic signal processing. A sentence in a reference said "To deconvolve the response of the measuring equipment from the backscatter data, a calbration spectrum (reference signal) is obtained by reflecting an ultrasonic pulse off a steel plate positioned in water at a distance corresponding to the center of the gated region." But I can not understand what's the last two words "gated region" mean. And a parameter in a formula is "gate length". I also do not know what is that in a waveform. Please gave me a help! Thanks alot!
(3,034 Views)
an ustrasonic equipment generally has one or more gates.
A gate is a settable time window to define a portion of interest where you want to do the inspection.
A gate is displayed on the screen as an horizontal line and it is defined by: start point, gate width (length) and gate Y position.
From your post I understand your reference signal is the spectrum of the reflected echo when the ultrasonic probe is placed at a distance from the steel plate to have the echo in the center of a defined gate.
Let me know if this was clear enough, I've been dealing with ultrasonic inspections for more than a while,
Alberto
(3,034 Views)
Thank you very much for your helpful answer! I am programming on the ultrasonic backscatter coefficient measurement and is facing some problems. If you can help me something on this region? Thanks!
(3,034 Views)
Hi again,
I'd be glad to help you if able to.
You can detail your application and problems.
My e-mail is: altek@tin.it
Alberto
(3,034 Views)
