What is the Scan from string pattern for "match everything" ?
Using Scan from string for a while, I know that %s only matches string up to a whitespace. And I also thought %[^] would match everything including whitespaces. But it turned out that it would stop at the closing square brace.
So, what is the real scan pattern for match everything including whitespaces ?
(3,832 Views)
I just tried it out and %[^] worked for my string. What does the string look like that doesn't work?
Remember Cunningham's Law
(3,754 Views)
Hello PeterFoerster,
With input [1,2,3]  , Scan from string pattern %[^]   would return [1,2,3   and the remaining string is ]
(3,706 Views)
Accepted by topic author sdfsdfsdfadgadf
What do you want the Scan From String to end on?  Or are you just grabbing the rest of the string?  If that is your scenario, then just use the "remaining string" output.  It might help if you give a full example of a normal input string and EVERYTHING you want as an output.
GCentral
(3,657 Views)
you just need a space after the caret
If you REALLY want a "Match everthing"  %[\00-\FF] (Case sensitive) matches one or more ASCII charaters in the entire set of possible characters
(3,645 Views)
Hi Jeff·Þ·Bohrer, crossrulz. All good inputs and are well solution. Thanks ! Smiley Happy
(3,605 Views)
I don't see any thank yous.  No kudos.  No marked solutions.  Jeff and I feel no love right now...
GCentral
(3,593 Views)
