What is the Start property?
What is the "Start" property of a graph scale?
If it is the lowest value, how does it differ from "Minimum"?
Chris
(2,714 Views)
"Minimum" is the lowest value of the scale.
"Start" is the value of the first (lowest) major gridline of the scale.
Fading out. " ... J. Arthur Rank on gong."
(2,714 Views)
The start property, as the other post pointed out is used for grids and
markers. It is typically set to be a multiple of increment. If you
wanted the scale to contain odds between 7 and 17, you will need to set
the start to 7 and increment to 2. If you let LV set the start, it will
place the markers at 8, 10, ..., 16 and have the outer markers at 7 and 17.
I hope that helped. If not, ask a more specific question.
Greg McKaskle
(2,714 Views)
