I am configuring tags using LabVIEW 7 PDS Datalogging and Supervisory Control Module. In the Tag Configuration Monitor > Tag Configuration > Scaling window, I can set values for the Raw Scale and Engineering Scale. However, when I input a value such as 32767 into the Full Scale box, the value is quickly changed to read 3,28E+4.
what is this actual value that is being used?? Is it the same number as I have entered, or has it been rounded to 32800?
