What is the best achitechture for DAQ?
Hi Balaji,
Thank you for your example. I think it's kind of like what I expected. But in my case the situation might be more comlicated. I need some parrallel VIs running at one time. And I need some Feedback control in the future. I met with QSM-PC recently, and I think that might be the solution. But again, like Felix said, I'm not sure if I MUST use that achitecture.
Best wishes,
Bo
My blog Let's LabVIEW.
Message 11 of 16
(1,032 Views)
Hi Ben,
Your reply is so professional! Thank you for your illustration, and I'll be learning about it for a while. Thanks again!
to Ben, Felix, and Baj, I tried to give a kudos but failed. I'll re-give when possible. Thank you all.
Best wishes,
Bo
Message 12 of 16
(1,030 Views)
Hi fooloo,
Is your problem solved? If so please mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 13 of 16
(994 Views)
Hi Balaji,
Thank you for your attention. But unfortunatly I didn't figure out a better achitecture yet. State machine cannot run parrellel tasks. I found QSM-PC achitechture may achieve my aim, but I didn't master it and cannot tell if it works.
Best wishes,
Bo
Message 14 of 16
(988 Views)
Did u go through my example of State Machine with Queued base Function Global.
Balaji PK (CLA)
Message 15 of 16
(986 Views)
Hi Balaji,
Yes I did, but again it was for DAQ only, if I  wanna implement data analysisi and logging parrallelly, I dont think it is the best solution.Thank you for your reply.
Best wishes,
Bo
Message 16 of 16
(968 Views)
