What is the best approach for Continuously reading all DI lines of all the ports of a DIO device?
Hi! I am new to Labview ..... I want to monitor all the DI lines of all the ports of a device .... What should be my approach?
(2,425 Views)
Just check the same thing in LabVIEW help you have examples which clearly tells you how to read DI lines you can make use of that
(2,421 Views)
Have you looked at the examples that ship with LabVIEW? If you go to the help and look at the example for DIO you should find and example:
Tim
GHSP
(2,419 Views)
