1) Get a old keyboard,
2) determine which pins on the character generator are connected to the function key(s),
3)remove the character generator and keyboard cable (intact),
4) wire your normally open switch (footswitch) to the necessary pins and put it in a project box,
5) assign this function key to your "start test" button on your vi,
6) connect the keyboard cable on the project box to a keyboard splitter (y-cable);
when your vi is running and the switch is closed, it will have the same affect as pressing the function key on the keyboard ---triggering your vi to start
I've used this (very cheap and easy) technique several times. Most PCs can handle two keyboard input on the keyboard connection. However, three is often too many (i.e., barcode scanner, k
eyboard, and footswitch). I've wired the footswitch straight to the working keyboard in these cases so I can also use a barcode scanner with a keyboard wedge.
