What is the best way to create a timer that counts up and down automatically?
I found a guide to create a countdown timer, but in this case, I want the timer to automatically count up and down from zero to a certain value.
This is the countdown guide: http://www.rmuti.ac.th/user/nopparat/document/pdf/LabVIEW_Lab6.pdf
(3,148 Views)
Get the labview success package. It contains a lot exercises about timers. however if you want to count down
get the current timer value, add the top value and then each call subtract the current timer value from the sum.
stop when the sum is zero.
(3,129 Views)
I guess you're a little lazier than the last guy that asked this very same question and your homework is due Friday?  😄
Bill
CLD
(Mid-Level minion.)
(3,122 Views)
Same guy;  duplicate post at http://forums.ni.com/t5/LabVIEW/What-is-the-best-way-to-create-a-timer-that-counts-up-and-down/m-p/3...
(3,119 Views)
