FSRI wrote:
> What is the difference between VI's for LabVIEW from one company
> compared to another company for the same piece of equipment?
> I am trying to control a camera, frame grabber and stage using
> LabVIEW. We have the VI drivers for the stage and we have them for
> the frame grabber. The problem is that the ones for the frame grabber
> came from another company then who we bought the frmae grabber form
> and so they won't recognize the instrument becuase the name is
> different. I am pretty sure that the configuration is the same for
> both companies instruments though.
You are talking about PCI cards here. Unless one card is an OEM product
or a clone of the other, they are seldom to be considered the same
eventhough they might use the same ICs.
Such cards come with their own drivers and some sort of API. This API is
either the system API such as VfW, DirectShow, QuickTime or whatever or
a proprietary API such as NI-IMAQ. If your VIs use the proprietary API
they will only work with cards which support that API, in most cases
this means only cards from that manufacturer. If your VIs use the system
API they will usually work with any card which has support for that API
such as VfW or DirectShow on Windows and Quicktime on MacOS.
> So now I need to write new drivers for
> the Coreco Frame grabber that we have. Problem is the experiment
> ships out in four weeks, so it must be done by then and I don't know
> if I can write drivers from scratch in time, plus have testing time.
> Does anybody know a short cut or how I could use the drivers that I
> have and change them somehow to be compatable with the other companies
> instrument?
Well, you say a lot about these things, but besides of the card you have
you tell little. What sort of driver do you have which will not work
with your Coreco card? Why do you believe this driver should work with
your card other than that it is a frame grabber too?
In my experience and seeing your time constraints I do not consider
development of a new driver, even if it is just the VIs, an option
unless you can spend a very serious part of those 4 weeks just for that.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
