What is the difference between buffered acquisition and non buffered acquisition?
What is the difference between buffered acquisition and non buffered acquisition? How will I decide whether I want buffered acquisition or non buffered acquisition?
(3,444 Views)
The difference is that you use a buffer or not.
So either you get a certain amount (maybe fixed size, maybe variable) with every iteration of your loop in software or you get just a single value (single point acquisition).
Very often you have to use buffered acquistion because of high sample rates or high channel count.
Christian
(3,430 Views)
I will also add that with non buffered acquisition you have to use software timing. Windows is not a real time OS, so the the timing is not accurate. But if you use buffered acquisition the timing will be controlled with an accurate internal clock on the Daq unit. I think non buffered acquisition should be avoided in most cases.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,427 Views)
"I will also add that with non buffered acquisition you have to use software timing."
No, you can e.g. use "1 Sample Hardware Timed".
(3,411 Views)
