What is the equivalent to "Array Empty?" but for digital waveforms? - an issue with DAQ Acquisition loops
I am trying to adapt the acquisition loop structure used previously for analog waveforms into a new acquisition loop for digital waveforms. However, the "Array Empty?" function seemingly does not work in this case. What would be a similar function? You can find below a picture of the part of the code that is not working, and I also upload the corresponding VI file.
Thank you for your time and help!
Fl0
(836 Views)
It seems like You've replaced the Array of Clusters with a single Cluster.
If You look at the tunnels in the for loop and compare them to the Tunnels on the analog waveform, they're different.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(814 Views)
Accepted by topic author Flonares
Hi Flonares,
in the analog waveform section you read "N channels", in the digital section you read "1 channel"…
When you don't need to handle arrays, then you need to check for empty arrays!
(781 Views)
Hi GerdW, and many thanks - I absolutely overlooked it... Many thanks!
(776 Views)
