What is the installed size of the LabView 7 Runtime Engine for Linux?
I would like to know the size of the LabView runtime engine after installation under Linux.
(2,741 Views)
Greg,
The size of the installed LabVIEW 7.0 run-time engine for Linux is 4,702,252 bytes.
D. Putnam
(2,741 Views)
I just install the LabView 7.0 runtime engine for Linux, but the install appears much larger than the 4,702,252 bytes you mentioned. The /usr/local/lib/LabVIEW-7.0/liblvrt.so.7.0 is 7,328,272 bytes, and the /usr/local/lib/LabVIEW-7.0/lvapp.rsc is 2,773,251 bytes. Can these files be removed and still have the run-time engine work?
(2,741 Views)
